Dryer has no power
Hi emer, this is AP!
I understand you are having trouble with your Frigidaire gas dryer. Without knowing the specific model number there are still some troubleshooting tips I can recommend. Make sure the dryer is plugged into the outlet, and plugged in correctly. Check to see if the house fuse is blown or circuit breaker tripped. If so, replace fuse or re-set circuit breaker. Make sure that the electrical circuit is not overloaded and correct. Additionally, the dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. If needed have a licensed electrician check to make sure it is on a circuit by itself.
If those tips do not resolve your concerns and the appliance is still in warranty, you may want to check with the manufacturer to determine any warranty coverage, or if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost if is something simpler to repair. I hope this information proves helpful to you.
Best of luck,
