I had my windshield replaced last week. We had a bad strom last night. This morning my front carpets are wet and the hummer wont start. Could this be related, what do I look for to try drying out, is it fixable?
SOURCE: Hummer H3 rear lights staying on
if it is the brake lights that are on check the brake light switch on the brake pedal
SOURCE: 06 hummer h3-water on passenger floor after a rain
Hey I have the same problem, but only when it rains, it comes from the sunroof then leaks into the carpet.
SOURCE: 2006 Humer H3, Won't start and electrical resets itself
Check the battery terminals real good.Make sure they are clean and tight.Check and see if any of the side terminals are leaking. As far as the blower motor.It is more than likely that the blower motor resistor is bad.It is located by the blower motor.Hope this helps.Good luck.
SOURCE: h3 hummer 2006 model.....hot floor board, passenger side
The hot floor is the catalitic converter. It may be bad, but you need to find out why it got hot. usually lean codes will be present with this problem. could be a bad vacuum leak. mass air flow sensor could be bad. as far as the water being a 2006 I do not think it is the windshield, probably the drain is plugged up for your a/c look under the hood, passenger side, there should be a tube that hangs down around where the a/c lines go in to cabin. you can try to back flush it or run something up in it to free it up. good luck
