Retail Supplies Logo
A
Anonymous Posted on Mar 18, 2014
Sharp era420 not printing on left side - Sharp Retail Supplies
Karo Shito
Level 2:
Habit-Forming:
New Friend:
  • Expert 70 Answers
  • Posted on Feb 22, 2016
Karo Shito
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
70
Questions
0
Helped
61777
Points
409
NZ Till Man
Level 1:
New Friend:
  • Contributor 45 Answers
  • Posted on Mar 18, 2014
NZ Till Man
Contributor
Level 1:
New Friend:
Answers
45
Questions
0
Helped
14260
Points
53
If its feeding paper but not printing, make sure that you are using the correct thermal paper and that there is no extra bits of paper stuck under the printing head. Otherwise it might need a replacement printing head. If its not feeding the paper at all, then make sure that the receipt is turned on.
Brand New Sharp Printing Calculator won't add or print.
Look for a reset button on the bottom of the machine.
tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
2helpful
Colored lines are printing on the printed copies. It does not occur when we copy items, only when they are printed. The maintenance code "AA" is on the screen as well. I don't know what that code means....
When this happens, you need to clean the scanning area. When you lift the top cover, you will see a green clip on the right hand side (of the actual cover) and you clean the scanning section on the left hand side on both the bottom of the cover and on the base where you would put your original copies.
Then open where you put the toners in, and pull out on the green rods a few times each, and this will help clear the grid.
Can not take colour print out, black colour printing is alos not very sharp, left side printing is very dull
problem with drum unit. sometimes unit comes with cartridge and sometimes as a maintenance kit.
11helpful
2answers
Sharp al-1631 copier. drum error code
You can reset this indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
Don't know how to void a previous sale
If you make an incorrect entry relating to a department, PLU/subdepartment, percentage (%through •),
deduction (-through ≠) or refund, you can void this entry by pressing the void key (looks like infinity sign)immediately after the
incorrect entry.
Sharp arc 262
Open the Left side door and remove the fuser unit by unscrewing the large green wheel located under the frame on the left side door below the fuser unit. Lift the fuser unit using the handles front and rear sides. (be careful it is very hot). Set the fuser unit on a table or counter or desk. Look carefully at the left side, as it sits in the machine, near the middle. You should see a actuator for a sensor. Make sure both ends of the arm are in the holes where they shoud be. If it is out of place, put it back into place and carefully place the fuser unit back in the machine. Secure the fuser back in the left door and close the door.
Top Sharp Retail Supplies Experts
k24674
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
