Fuel pump is located inside the fuel tank access cover location. Here's the details:
- Properly relieve the fuel system pressure.
- Disconnect the negative battery cable.
- Open the rear access door.
- Release the catch for the back seat and tilt the seat out of the way.
- Move the carpet behind the seat that covers the fuel pump access panel.
- Disconnect the fuel pump electrical connectors.
- Remove the screw securing the ground wire.
- Remove the four screws securing the fuel pump access panel and position it out of the way.
- Remove the hose clamps connecting the fuel hoses to the fuel pump.
- Disconnect the fuel hoses from the fuel pump.
- Disconnect the fuel tank pressure sensor electrical connector.
- Remove the eight retaining screws securing the sender assembly to the tank.
WARNING
The fuel assembly is easily damaged. Use care when removing the assembly from the tank.
- While twisting and tilting, gradually lift the fuel sender assembly and remove from the tank.
- Wrap the fuel pump assembly in a rag before removing the assembly from the vehicle.
- Cover or seal the fuel tank until installing the fuel pump assembly.
- Remove the retaining hardware that holds the sender to the fuel pump assembly.
To install:
- Install the retaining hardware that holds the sender to the fuel pump assembly.
- Remove the temporary covering or seal that was used to protect the tank.
- Install the fuel pump into the access port on top of the fuel tank.
- Carefully, twist the fuel pump as necessary to properly position it in the fuel tank.
- Install the eight retaining screws securing the sender assembly to the tank.
- Connect the two fuel hoses to the pump and secure with clamps.
- Connect the fuel tank pressure sensor electrical connector.
- Insert the ground wire and fuel pump electrical connector through the access hole and install the access cover.
- Connect the fuel pump electrical connector.
- Secure any loose wiring with adhesive tape and reattach the carpeting.
- Release the catch for the rear seat and put the rear seat in the normal position.
- Close the rear access door.
- Reconnect the negative battery cable.
I can help you further and show you where you can access the information for free. Good luck!
