The error code chart indicates that this could be a water flow problem, too low of a drain hose height or an over-sudsing problem. Start new cycle on a cold cold setting if applicable. See if cold water comes in. Make sure your drain hose is higher than the top of the machine. When looking inside the glass door....do you see lots of suds?
Waiting to hear from you,
Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
