Question about Precor Exercise & Fitness
Treadmill circuit board not activating - Precor Exercise & Fitness
Replace main control board
Is the wall receptacle defective? Have you plugged something else into the same wall receptacle without circuit breaker activating? Test with another appliance that also has the third round ground prong. If this is not the problem then yes an electrical short exists within the treadmill, inspect the cord itself for loose prongs, there may be liquid damage inside from a previous liquid spillage which would cause an electrical short.
Dec 22, 2013 | Nordic Track Exercise & Fitness
Endex DCMD 57 Treadmill power board, will not power up, cuts out almost immediately.
Hello from Greece!
If you see the red led (D1) on when you press the start button on your treadmill you have a short-circuit on your 20N60 transistor. replace this transistor and your DCMD67 circuit board will be new! but be careful, if this happen on your circuit board, In about 90% you must have problem with your treadmill motor or your treadmill belt.
If you have any other question just mail me.
Have a great day!
Oct 04, 2013 | Exercise & Fitness
Track 5500
Go run in the park, much softer landing if you fall again, no cost involved. Use the treadmill as a clothes hanger.
Oct 08, 2012 | Treadmill Doctor Exercise & Fitness
Supplier for a Tunturi T85 treadmill circuit board?
Here is a parts list for the Tunturi T85 with many available parts. I don't see a circuit board but you may be able to contact the company to see if it has a different name or if they can get it added.
Sep 14, 2012 | Tunturi T85 Treadmill
Treadmill stuck in -3 incline
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Unplug treadmill from wall outlet. Wait 60 seconds, allowing lower board to discharge built-up energy.
Remove motor cover.
Verify that there are no lights lit on the lower circuit board.
Verify that all wires are securely and correctly placed on the lower circuit board, especially the large wire harness on the top of the circuit board with 12 different colored wires coming out of it.
Dec 09, 2011 | Nordic Track NordicTrack COMMERCIAL 1750...
9.33 treadmill set manual 30 min. completely shuts off somewhere between 22 & 24 mins. It's plug into an outlet on a 20 amp breaker. Got any ideas? Purchased brand new in April
hi,
It have some problem with motor controlling circuit board. The repairing in the circuit board of treadmill should done by an experienced person in it, because there are harmful high voltage areas in the circuit board. Consult some one who is experienced in it.
ok
May 22, 2011 | Precor 933 Premium Series Treadmill
UNIT DOES NOT POWER UP. I CHANGED THE POWER BOARD WITH NO RESULTS. POWER BOARD 120 VOLT LIGHT IS ON. 9 VOLT DC LIGHT IS ON. PWM & TACH LIGHTS ARE NOT LIT. CONSOL DOES NOT LIGHT UP
If its a Icon Health and Fitness branded treadmill (proform,image ,healthrider etc.)The safety key activates the on off switch for the console. (micro switch activated by safety key)Check for 9-12v going to console. Unless it has a magnet switch. What brand and model ?
Sep 11, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
How do I fix my Endurance Treadmill TF3i Err7 problem? I stopped during operation.
Unplug unit remove motor shroud check connections on lower board (incline board). I believe their is a 3 amp fuse in circuit check with multi meter to see if open replace fuse power up unit and if it blows the fuse then replace incline motor and if not, then use engine mode press stop then Incline + or - to force incline up to max incline then bring it down to 0 then turn off power then wait 10 seconds then hit power on then if error does not appear then hit start and resume using unit. If the procedure above does not activate unit then replace board.
Apr 15, 2010 | Endurance T3 Treadmill
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
Treadmill wll not start, have changed the circuit breaker but get no activity on console
you have to have the little magnet on the front of the treadmill. If it is an old treadmill, you may just need to get a new one. Hope i helped!!! :D
Jul 13, 2009 | Proform 760 CrossTrainer Treadmill
Exercise & Fitness Logo
29 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
