I had virus's on my pc. Everything was wiped off and no my audio devices arent working. In control panels it says I have no audio devices and doesnt allow me to use to drop down boxes to change any of the settings. Does this mean my sound card has been unistalled? If so how do I get another sound card? I purchased the speakers with the pc and all was working fine until this happened. The speakers do turn on as I can hear interfearance with my phone etc but I cannot get any sound from them? Please help . ..!
I have the exact same problem, what i suggest is finding your manual, and CD to install (if u have one) because i remember this problem a while back when i first got it, but after i installed it was ok...if you dont have the manual or disk, you could look for an online instalation manual (which is what im doing right now)
Poo
how do I...
Thats exactly Whats Happend.
Please help!
Its Anoyying :)
Thank you x
How do you get the sound card?
The Problem is you need to install th sound card.
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
have you tried this control panel sounds and
connection is good
hope this helps
connection is good
hope this helps
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
same as other guy
deleted my hard drive due to virus. cant access any volume control by any means. all windows trouble shooters calm enable and disable. however, this option is in shaddow and i am unable to do that! please help!
i have no disk to re install what can i do
i had too much viruses and had to get my computer cleaned up and then all of my files and folders got deleted and i dont have the installation disc for my speakers and i dont know where to download it from. Can anybody help me please...
A fried just gave me some Labtec speakers, she said "just plug them in and they will work, but the left one does and the right one does not. What could it be? as simply as possible please, newbie here..
I have the same problem, but my soundcard is working because I can hear sound through headphones, but none through speakers. Where can I download a drivers for these speakers? If that's what it needs?
how do you dowload the sound card so i can install it
