SOURCE: Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
SOURCE: bathmat disintegrated in front loading maytag 5000
Unplug the machine,bail out as much standing water as you can,remove the bottom panel 3-4 screws 1/4 inch driver.the pump sits right in front turn the handle to the left have plenty of towels,make sure you keep the Motor control board on the left dry,you will find a filter there that catches most debris but check the out going hose on the other side of the pump as well.
SOURCE: Maytag NFW7200TW leaking
The door seal is leaking and it is either installed incorrectly or just needs to be replaced. If the machine is under warranty, call the service people now. Hope this helps
SOURCE: maytag washer top load neptune
See this post for troubleshooting the Lr error code. . http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Lr is locked rotor. My first thought was that this could be a Motor Controller issue. This owner replaced tried that and it did not resolve the issue. He then replaced the main Control Board and that fixed his machine. Without known good parts (Control Board Motor Controller) this might be difficult for a DIY fix.
The Service Manual for reference. Sears Parts Direct for reference.
If you are going to try to DIY the repair I will see if I can help……Rich
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Hi
There is only one Analog Pressure
Sensor Switch Part no. W10156252, another one that it has is the water level switch (part
no W10415587). I believe you are
talking about the first one as that is what error code F35 means (ANALOG
PRESSURE SENSOR FAILURE). Hope
this helps...please post back for further assistance.
Daniel
Hello &
Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
