Below are instructions to adjust brightness on HP laptop
Press the "Fn" key with the computer turned on and hold the key.
Press the "F7" or "F8" key on some HP laptops, which are
printed with a small sun icon on the key. The sun icon is filled on the
function key for dimming the laptop. The other key is printed with a
hollow sun icon for brightening the screen.
Press the "Fn" and left arrow keys together on some HP
laptops to turn down the brightness. The "Fn" and right arrow key will
increase brightness. Press and release the right arrow key repeatedly,
while holding down "Fn," to decrease the screen brightness slowly, or
hold the keys to darken the screen as low as the setting will go.
For HP Monitors
Press and hold the down arrow key on the front panel of the
monitor below the screen to turn down the brightness on the external
monitor to the lowest setting.
Repeatedly press the down arrow button to dim the monitor gradually.
Press the up arrow key on the monitor to increase brightness.
Press MENU (Button 1)
Then DOWN Arrow followed by ENTER (Button 2)
Then DOWN Arrow followed by ENTER (Button 2) and you should be in the Brightness Menu
Press the Menu key on the Monitor to bring up the dialog box press Menu again because it defaults to the Brightness Icon. You will see the lower half of the dialog box change color. Use the left or right arrow to move off of Acer eColor Management to the User setting. Then press Menu again to edit contrast or brightness. User the left and right arrows on the Monitor to move to the desired adjustment, press Menu to allow adjust then arrow left for less or arrow right for more.
You really just keep moving between the Menu and arrow til you get it right.. I definitely needed to turn down the brightness on my monitor.
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Well most monitors come with 2 preset color temperatures and the option to customize it(the rgb setting). Your monitor has them as well 6500K or 9300K. 6500 is more reddish(like outdoors) and 9300 is more a bluish white(like a tv, i like the 9300 more).
How u said its red and bright, what i would do is set the 9300 preset and if its still too red the customize the RGB by lowering the red. and If too bright then Lower the brightness(Press down on BRIGHTNESS CONTRAST page).
If you don't have the manual you can download the full manual from LG's download site here:
http://www.lge.com/support/manual.
If you see that you can't get it just right,then the monitor might need adjustment from inside and you should make a qualified technician open the monitor and adjust that for you.
Hope this was helpful.
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
