Ricoh Aficio 2035 Copier Logo
Talib Rehman Posted on Mar 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sc 395 keeps comming up after 1 print
quennie732
Level 2:
  • Ricoh Expert 422 Answers
  • Posted on Mar 21, 2014
quennie732
Ricoh Expert
Level 2:
Answers
422
Questions
0
Helped
236178
Points
775
Staple or paper clip on/in developer assy
1helpful
2answers
Model 560. What does error code 062-395 indicate?
http://www.manuals365.com/swf/fuji+xerox/ag-c560p_c550p.html?page=207
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Sc 395 ricoh aficio 3045
10helpful
Hi.... sc 395 with aficio 1045 , what is that mean & how can I fix it.
If it's 395 that's a development bias error, check and reset the developer. Power off/on to clear both.
Oki Microline 395 install problem
This printer will print with the Windows Generic/Text driver. It can also be set to print with IBM or Epson FX drivers. Follow these steps:
1. Press on the "SHIFT" Button, while holding it down press the SEL Button. The "SEL" Indicator will light up.
2. On the controll pannel, press the "PARK"
Button. The Printer will print a Setup Page.
The last line that is printed will be what it is
set to - ML or IBM or FX.
3. With the "TEAR" button you can set it to
the driver you want.
4. To save the config you selected, Hold the "SHIFT" Button and press the "SEL" button.
The "SEL" indicator will turn off and save the configuration.
Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Ribbon Slips Off Okidata ML 395
Your printhead is in correctly but not aligned, Please loosen the 2 screws that holds the printhead.Remove ribbon(all this while the printer is powered off) Now look on the right side there is a lever that makes the printer go closer to the ribbon ,move the lever to number 9 and move the head over to the left side of the printer.push the head forward slightly towards the black roller and tighten the 2 screws again ,install the ribbon and move the blue lever to 1 and try printing again.
Hope this helps.Dezzi
AC adapter
The E-7AU AC Adapter is designed for the D-395 Digital Camera. It outputs 3.4 Volts at 2.5 Amps. The stock number is 200751. It can be purchased through an Olympus dealer or the Olympus Emporium at https://emporium.olympus.com/ or 1-800 201-7766.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
