Motorola Mobility RAZR XT910 Logo
A
Anonymous Posted on Mar 17, 2014
How to record sound - Motorola Mobility RAZR XT910
  • Official Brand Answer 1,623 Answers
  • Posted on May 16, 2016
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350717
Points
5677
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster spray..it may be dirty..
tip
How to computer capture a sound card
<p>Record and recording the sounds through the computer sound is a relatively simple procedure that only a free space on the hard disk, suitable software and a short profile of TRS cable is required. Windows computers usually come with an audio recording program, from the entertainment equipment a program is found in the Start menu. <br /> <p><br /> <p>1. Turning off the computer speaker's audio jack of your computer's sound card. <br /> <p><br /> <p>2. Attach the small RCA cable into the sound card speaker output. <br /> <p><br /> <p>3. Connect the other end of the RCA small correction to the microphone port on your sound card. <br /> <p><br /> <p>4. Start the Sound Recorder program from the Start menu. Click the Record button. Tell your computer to the sound you want music or video progress bar to take to indicate when the movie is ready to play. Click the Record button, which will continue to record. <br /> <p><br /> <p>5. Click the File menu in the Sound Recorder program and select "Save As". Enter a filename and click Save. <br />
on Jun 22, 2011 • Computers & Internet
5answers
How i can recorde
Music or video ?????
If video you can install vlc player from here free:
http://www.videolan.org/vlc/
When installed click on show in the menu bar
and select advanced control now the player can record.
When click on the record button.
And it will create your video in your video map.
For music also for free you can install this recorder from here:
http://www.sound-recorder.biz/freesoundrecorder.html
Free Sound Recorder does exactly as it sounds -- it is an easy-to-use FREE software program that lets you record any sounds from your sound card and save the recording directly into MP3, WMA or WAV files.
Free Sound Recorder is a perfect audio recorder to record your own voice, music or any other sound by working directly with your sound card. It supports the record input/source from a microphone, streaming audio from the Internet, external input devices (e.g. CDs, LP, music cassettes, phone line etc.) as well as other applications like Winamp, Media Player, etc. With built-in advanced audio record engine, the recorder produces high quality recordings.
If you're looking for an application to help you for audio recording, you won't be disappointed in Free Sound Recorder! Main Features of Free Sound Recorder
bg_link_arrow.gif Allows you to record audio into MP3, WMA or WAV format directly.
bg_link_arrow.gif Allows you to pre-define audio recording qualities to help quickly set and manage recording parameters.
bg_link_arrow.gif Built-in advanced audio record engine to produce high quality recording.
bg_link_arrow.gif Allows you to preset/preview your audio recording device before starting record.
bg_link_arrow.gif Build-in WMA WAV MP3 decoder.
Hope this was helpfull
5helpful
3answers
No sound recorder
located in your windows\system32 directorys file is called SoundRecorder.exe no problem just please vote
Speakers
I suggest that you check and ensure that the correct playback and recording device is selected in the sound properties of your system. Please refer to the steps below as a reference.
1. Click on Start > Control Panel.
2. In Control Panel click on classic view, located at the side bar.
3. Next double click on ‘Sound’ and go to ‘Playback’ tab.
4. Please ensure that under ‘Playback’ tab; the headset is selected as default device.
5. Next go to ‘Recording’ tab and ensure that the microphone of the headset is selected as default device.
6. Now, try to take a test recording using Sound recorder.
7. Click on Start > All Programs > Accessories > Sound recorder
8. Take a test recording with Sound recording using the microphone of the webcam. Then playback the recording and check whether it was recorded clearly.
3helpful
How to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
2answers
No Sound When Recording
where will get the hp pavilion audio drivers for xp professional
No sound
have good picture from pre and recorded tapes, but no sound.
Does the L410 do audio recording?
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos
You can record and play back sound memos for your photos while you view them on the LCD screen.
1. Turn the Mode dial to playback mode.
2. Press the MENU button. Playback Menu 1 is displayed.
3. Select Sound Memo by using the u d buttons, then press the r button.
4. Press the OK button and then start recording.
5. When you are finished recording, press the OK button. You can play or delete the sound memo or record
a new memo.
6. Press the MENU button twice to exit the menu.
When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK
button to play the sound.
Note:
You must have at least one photo saved to record a sound memo.
Top Motorola Mobility Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
john h
August Brown
August Brown
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
