Question about Casio FX991ES Scientific Calculator
Hyperbolic trig how to input in the calculator
  • Abdu Yimam
    Abdu Yimam Jan 28, 2019
    thanks but the problem is numbers are always tricky!
  • Casio Master
  • 8,081 Answers
You cannot use the two words in the same sentence. To use the hyperbolic functions, press the HYP key. The display will show you what follows.
1: hyperbolic sine, 2: hyperbolic cosine, 3: hyperbolic tangent, and their inverses.
To calculate the hyperbolic cosine of the number 27/3, press 1 in the first screen capture, you get cosh(. Complete the expression and press=
Posted on Mar 19, 2014
SOURCE:
Binompdf ( says n:......p:.....x:..... How can I enable this guided input on my TI-84?
In the older versions of the OS, the command binompdf( displays a command line where the user is expected to enter the arguments respecting the syntax of the command. In the more recent versions of the OS (the most recent is 2.55 MP) the user enters the input over three lines.
I suggest you upgrade the OS of your calculator to the latest version available on the education.ti.com website.
To upgrade, insert fresh AA batteries (or just good batteries), run TI connect on your computer, connect the calculator to the computer and click the update button on TI connect main screen. It will download and update the OS.
Jun 25, 2012 | Texas Instruments TI-84 Plus Calculator
What is the meaning of MthIO in a CASIO calculator?
Math Input/Output. This mode shows the input expression and the result in more commonly seen in math books, with raised exponents, numerator stacked above denominator, and so forth. The other mode, LineIO for Line Input/Output, shows everything on one line.
Mar 28, 2011 | Casio fx-300ES Calculator
I am unable to do a fraction on this calulator please show me how to do this
The [U n/d] key allows users to input mixed fractions using the TI-30XS/B or TI-34 MultiView scientific calculator. For example, to input 2 3?4, follow the instructions below:
• Input 2 and press [2nd] [U n/d].
• Input 3 and press [down].
• Input 4 and press [right] [enter].
Oct 09, 2010 | Texas Instruments TI30XS Scientific...
I need to reset the TAX percentage on my calculator
1. How to set "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator,
1. Press [AC] and hold [%] for about two seconds.
2. Input Tax Rate and then [%].
* You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator,
2. Input [TAX+].
3. Input Tax Rate and then [%].
Oct 01, 2010 | Casio MS-80TV Scientific Calculator
We have several MS-170TV's I have misplaced the instructions. How do I re-calculate the Tax Rates at 15%? Terry
Q2
Please tell me how to do "TAX calculation".
A2 1. How to set "Tax Rate"
2. Input [TAX+].
2. How to calculate Price-plus-Tax and Price-less-Tax.
(1) How much is Price-plus-Tax of 100?
Press [AC], and input 100 [TAX+].
(2) How much is the Price-less-Tax of 105?
Press [AC], and input 105 [TAX-].
Oct 01, 2010 | Office Equipment & Supplies
Can i calculate calculus using fx-991ms
If you want to get an answer like 1/2X for d/dx(X^2), you will have to purchase a CAS calculator like Casio's Algebra FX-2 or Classpad. TI series calculators also have CAS.
However, you can calculate the numerical values of derivatives and integrals only.
To calculate the value of a proper integral:
  1. Press the 'ON' key;
  2. Press the Integral key b8325f5.jpg;
  3. Enter your expression (example X^2+X-3 etc);
  4. Press the 'comma' key after your expression;
  5. Input the first limit after comma, input comma again after first limit;
  6. Close brackets;
  7. Press the equals key, display may return after a while with the answer.
for eg to calculate xdx from 0 to 2, input as follows:
dx(X,0,2)
To calculate derivative at a point:
  1. Press Shift and then the integration key.
  2. Enter your function;
  3. Input comma;
  4. input the point at which you want to evaluate the derivative;
  5. Close bracket and press enter.
Example, to calculate d/dx X^2 at 3 input:
SHIFT+dx key X^2,3)
Display looks like this: d/dx(X^2,3).
Oct 23, 2009 | Casio FX-300MS Calculator
How do I program the calculator tax+ Tax- buttons?
1. How to set/ change "Tax Rate"
2. Input [TAX+].
Press [AC], and input 100 and then press [TAX+].
Calculator will display 105 if tax rate is 5%
If you press [Tax+] again, it will show the tax amount..
Press [AC], and input 105 and the press [TAX-].
Calculator will display 100 if tax rate is 5%
If you press [Tax-] again, it will show the tax amount..
Jul 29, 2009 | Canon LS-100TS Calculator
Hi i have the canon p170-DH and i cant subtract. example: 4-4= -8 not 0
Hi....by looking at the date you posted this question, you may have already found the answer, but just in case you haven't......the procedure for adding and subtracting on these calculators is completely opposite of a regular calculator. On a regular calculator, you would input 4 - 4 = 0. On these type of calculators, a number's positive or negative status is keyed in AFTER the number, instead of before it. Therefore, you input 4 + 4 - (notice you DO NOT input = at the end, but if you are in print mode, you will need to hit your total key, which looks like an asterisk, where the = would normally be, in order for the final value of your calculations to print on the paper tape.
Multiplication and division equations are done exactly as they are on a regular calculator....4 x 4 = 16.
Hope this helps. If you have your owners manual, it should also give you some examples of how to perform calculations with your calculator.
Dec 11, 2008 | Canon P170-DH Calculator
Percentage button!!
they call it hardware malfunction. try removing all batteries in it and wait for 30 seconds before reinserting the batteries. If the same problem still exist, the unit is permanently damaged.
Aug 23, 2007 | Casio MS-80TV Scientific Calculator
How do you set the tax rate?
press AC press and hold set key for2 seconds, until zero appears on the screen press tax+ input tax rate press set check by pressing AC, then pressing tax+ key. It should be the tax rate you inputed.
Aug 18, 2007 | Casio DF-120TV Calculator
Casio FX991ES Scientific Calculator Logo
574 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
