USA com provides easy to find states metro areas counties cities zip codes and area codes information including population races income housing school crime rate weather...
If he knew how to disassemble the faucet but it was corroded so badly it would not come apart<?>... sometimes a Dremel with cutting wheel is the only option.
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
The handle assembly and collar (8) will thread off after pushed past the limit of the cartridge (gentle consistent pressure)...
In terms of leak itself its hard to say but if the faucet froze from sediment build up and is now leaking it is likely that part of the cartridge is 'clogged' open...
