The screen goes out at times. pressing the keyboard on the edges correct the problem temporarily
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective.
If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
Hope this helps
Please go through the below step, you can able to do it.
1) Shut down the Dell Latitude D620 if it's currently powered on. Click "Start" in the left-hand corner of the screen to access Windows' shut down options. Alternatively, press and hold the Latitude's power button, located on the top edge of the laptop's keyboard.
2) Turn on the computer by pressing the laptop's power button.
3) Press and hold "F8" on the top of the laptop's keyboard immediately after turning the computer on. If the Windows logo appears on the screen, you're too late and must repeat Steps 1 through 3 again. If you pressed it in time, a list of text options will appear on the screen.
4) Use your keyboard's arrow keys to scroll down to "Repair Your Computer." Push the "Enter" key on your keyboard.
5) Choose a language from the next list and select "Next." If you've password-protected your laptop, you will be prompted to enter your user name and password at this time.
6) Press "Dell Factory Image Restore." A new window will appear. Click "Next" and select the option for reformatting the hard drive and restoring the factory condition of the laptop.
