Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Connection to internet through BTVOVAGER2091
I have installed The Belkin Adapter and have an Icon on the desktop and on the taskbar. The taskbar icon shows blue indicating a connection. IE reports that it can't contact the server. I don't get on the internet. I have a Sony laptop that works fine wirelessly through the BTVOAGER2091 router
  • thomson52 Nov 01, 2007
    I cannot see any answer to my problem on this page and therefore cannot rate it.
  • Anonymous Dec 29, 2007
    wired every thing up still cant get a connection
  • 3 Answers
What do you mean clone the MAC address cause i have the same problem.. with 2 wire router on emachine pc desktop. srry this isnt really a solution for u unless your confused like me about this cloning 0_o.
Posted on Dec 24, 2007
    Problem Solver:
  • 9 Answers
You need to clone the MAC Address of the Belkin Adapter.
Posted on Nov 01, 2007
SOURCE:
Why can't my dell inspiron 530s desktop install
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers. Hope this helps
Dec 19, 2012 | Computers & Internet
Belkin n150 wireless adapter- after installing software and plugging in the usb adapter my hp (running win xp pro sp3) will not display the desktop icon to open the wireless network manager. The hp sees...
Click on the start button on the lower left corner of your screen and go to "All Programs". Look for the wireless utility there of your Belkin wireless USB adapter.
Aug 30, 2011 | Belkin Basic Wireless N150 USB Adapter
Belkin Surf Network Adapter installed on my desktop connects to my wireless network and looks to be working ie. wireless icon in lower right hand corner is flashing blue with no red cross etc. However, I...
I got your issue , for your issue , I f you want to go online hard wired to the router , make sure the Local are connection in the comp is enabled as well you have coted that u can see red cross in the wireless network connection icon, so make sure do not have any preferred networks in the comp.
Thanks,
Prema
Sep 27, 2010 | Belkin F5D4070 Network Adapter
How do I show the Internet symbol at the bottom of the desktop screen?
Show the Internet Icon at Taskbar
Right click on Task Bar -> Properties -> Notification Area Tab -> Check Network System Icon Box -> Apply -> OK.
BTW
Symbol=>Icon,
Bottom of the desktop screen=>Taskbar
Aug 06, 2010 | Microsoft Windows Vista Home Premium...
NO AUDIO AND INTERNET dsl LAN ICON
install your sound and ethernet drivers. if you don't have the driver CD anymore. download the dirvers from the manufacturer's website (e.g. dell, hp, compaq)
May 07, 2009 | IBM NetVista PC Desktop
Cant get Wireless card to connect to netopia wireless router
There are some things you might try.
The Belkin card will come with third party software you can disable this utility by right clicking on the icon in the Taskbar and choosing "Use Windows Zero Configuration".
Then you will need to go into Control Panel >> Administrative Tools >> Services >> Wireless Zero Configuration >> Right click and check that the service is starting automatically >> click on Start >> Apply - that should then detect your wireless network and the internet.
Feb 25, 2009 | Netopia 2247NWG-VGx Wireless Router...
Belkin wireless G notebook network card problem
disconnect the divice from the computer, unistall the driver, reboot the system, the install the driver beforre connecting the divice
Dec 16, 2008 | Belkin (F5D7011) 802.11g/b Wireless...
I had a home network set up between 2 Dell Dimensions computers Computer 1.) which as the broadband modem and Netgear Router on it "this computer is a windows xp". Computer 2.) with the Belkin...
Assuming you can't get it to run from the desktop icon, as long as the driver is installed which it should be, you don't need Belkin software to run your connection.
the easiest way in Vista is to go to control panel>network and sharing centre and see if network discovery is ticked green.
If not on top left of window is connect to a network, then see if your wireless connection is listed, if so click connect, if not at the bottom of the window, click set up a connection or network and follow the wizard.
Sep 10, 2008 | Belkin Computers & Internet
Change user at remote PC then cannot connect
the other user wireless access permission migtht not be activated, enable the user wirless access
Dec 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Lose wireless internet when printer is on.
the only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected. If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem. The same can apply to a desktop pc if there is a usb problem Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting. Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed. Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
Jun 23, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
87 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
