LG DLE5977 Electric Dryer Logo
Posted on Jun 14, 2009
LG TD-C70040E dryer shows ELE/EHE code ....
A.m. dryer stopped in the middle of the program showing an ELE/EHE code. The watercontainer is empty and all sieves are clean. Where's the problem?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3366
Points
13
This happened to my LG dryer and I took of the raised back panel that covers the flywheel and there is a red reset button. This worked for me.
Good luck
Funny how this happened after 3 years exactly. hmmm
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
LG c70040e dryer not heating.
some there a reset button on the rear red give it press in wards and then try agin and see if it works
Feb 10, 2010 • LG Dryers
7helpful
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 • LG Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Dryer error code
is the dryer getting hot?
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Nov 09, 2008 • Dryers
12helpful
4answers
LG td-c70040e tumble dryer Clean Filter indicator will not go off
There is an access flap below the door on the bottom left.  Open the flap turn blue levers, take plastic cover off (there may be a bit of water there).  Clean the inside.  Problem solved
2answers
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Top LG Dryers Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Dryer Expert? Answer questions, earn points and help others
