Canon PIXMA  MP160 All-In-One Printer Logo
Posted on Jun 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My canon M 160 jammed, I pulled paper thru, now it won't print
I have error code 2 and alarm light on my Pixma M 160 Canon. I turn printer off and on again. I hear the cartridges move sideays inside printer until there is a loud click. The error code comes on. E2. I need to use this printer this weekend.
Chris Dornin
Anonymous
Level 3:
President:
  • Master 787 Answers
  • Posted on Oct 13, 2009
Anonymous
Master
Level 3:
President:
Answers
787
Questions
0
Helped
415379
Points
2913
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
3answers
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the error, the unit would require service:http://www.usa.canon.com/cusa/page.action
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
3helpful
Canon MP800 Error code 6A00 alarm flashing .turned off overnight ,turned on not working ,still same code and alarm . Will not do anything . Thanks ...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
6helpful
2answers
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
The printer wont pull paper thru
theres a piece of torn paper stuck in the feed path. i used to be a photocopier tech and that was a very common problem. get out a flashlight and a pair of tweezers...
1helpful
Alarm light is flashing and can not print
Hi
Try this
Solution 1:
Solution 2:
Solution 3:
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
1helpful
Error 6A00
Solution 1:
Solution 2:
Solution 3:
old marine
old marine
ZJ Limited
ZJ Limited
