SOURCE: i cant configure Edimax BR-6104K router with PLDT auto-connect DSL
Try set the Edimax router to accept a Dynamic IP from the ISP - cause I guess they provide it to you changed everytime you disconnect.
SOURCE: Don't know the username to "http://192.168.0.1" router Level One.
If you have never changed this from default then the user name will be "admin" & the password will be "password" or "admin. If you google the default password for Your router model then that shoud find it if this does not work. Don't forget to rate me if this works for you.
SOURCE: When I enter "http://192.168.0.1" it's asking me username and pas
hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
SOURCE: where is the reset button and why does my router keep going off
you can find reset button in back side of it.
Press reset button for 10 seconds you can press it with niddle .
Then ci\onfigure it again
You can access your router with
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
thenh configure it as your isp settings.
