on wash cycle, water fills tub but when it should aggitate it doesn't move and it make strange sound .on wash cycle, water fills tub but when it should aggitate it doesn't move and it make strange sound .
You can't post conmments that contain an email address.
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
if you are unable to turn the drum by hand it may have ceased due to a sock or item of clothing jammed in it behind the drum this in turn may have snapped the belt
A top-load washing machine is not supposed to move the tub on wash cycle, but the agitator in the center is supposed to rotate back and forth. If that isn't happening, there is a problem with the clutch or the transmission.
there is a little motor in the selector switch that moves the dial around. This little motor is defective and needs replacement. Sometimes it's sold separately and sometimes you need the whole timer.
