I need to no how many grams are in a cup
SOURCE: at's your problem?How many gram in a cup?
That depends. Cup is a unit of volume, while gram is a unit of mass. One cup of lead weighs a lot more than one cup of sugar.
SOURCE: i need to know how to get 100 grams converted to
I believe it would be much easier for you to use a kitchen scale.
1 cup is a measure of capacity (volume). The same volume of two different substances will correspond to different weights. Some substance are light, other are dense.
1 cup is about 236 mL. For cold water 1mL corresponds to 1 g
A table spoon is about 15 mL. With water that corresponds to 15 g. Recipes are not laboratory protocols that must be followed exactly.
SOURCE: I am using regular size chocolate chips. Calls for 300 grams. How many cups would be equal to that
Approximately 1 1/2 cups.
SOURCE: How do I measure 100 grams of peas?? I use measuring cups.
cups measure volume , you wish to measure weight. Try 100 ml equivalent , or a tiny bit more. 100ml is just over 3 ounces of liquid equivalent. In theory one ml is the same as 1 gram but the measure is for liquid. (water I think) A teaspoon full is about 5ml/5 grams. Slightly over the 100ml mark is a very rough estimate. A weighing scale really would be better
