XPEL Technologies 2006 Buick LaCrosse - CXS - X-Pel Headlight Protection Logo
Ryan Pavlicek Posted on Mar 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change a headlight in a 2006 buick lacrosse cxs?
Lewis Meyer
Level 2:
Scholar:
New Friend:
  • Expert 140 Answers
  • Posted on Mar 21, 2014
Lewis Meyer
Expert
Level 2:
Scholar:
New Friend:
Answers
140
Questions
Helped
36104
Points
304
If yours is like mine. open the hood, look down at the back of the lights there are two pull up plastic clips. pull them up and work them off the two T pins and your lights should just pull out. PS the lights may fall if your not holding them after pulling the clips.
1helpful
3answers
One high beam not working 2006 Buick lacrosse
Sampson, sounds like a bunt out bulb, which will need changed.
If you feel comfortable doing it yourself. Basically three screws, and you have to pull one plastic fastener from the fascia (bumper) and pull the bumper back a bit, and pull the assembly out. I believe it is in the manual, not bad to do. I will post a link to tell or show you how to do it. Press the helpful button
Headlight Change 2005 2009 Buick LaCrosse 2006 Buick LaCrosse CX 3 8L V6
2008 Buick LaCrosse Headlight Replacement
Thread how do replace the headlight bulb in 2005 buick lacrosse
Headlight Bulbs
1helpful
Fix a 2006 buick Lacrosse remote start that does not respond
chances are the wire connection from the unit to the car has broken.
Where is the horn located on a 2007 Buick LaCrosse
Horns on most late model GM cars are behind or below the headlight. Many of these cars have headlight that are very easy to remove. The are held in place with plastic slides.... you pull the slide or release (there are usually 2) and the headlight assembly will come out of the body. Then you can look for the horn.
1helpful
Friring Order
firing order written on intake manifold
What is a p0496 error on a 2006 buick lacrosse cxs
The P0496 DTC code is a generic code which applies to all vehicle makes. A quick search on the 'net shows that this code seems to be more common with GM (Chevy, Pontiac, etc.) vehicles. In Acura, Honda, Hyundai, Kia, and Mazda vehicles, this code is described "EVAP system high purge flow" which is the same thing.
try use maxiscan us703 to clear the fault code.
Top XPEL Technologies Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a XPEL Technologies Sport and Outdoor - Other Expert? Answer questions, earn points and help others
