Question about LG 37LG30 37 in. LCD HDTV
37lg30 usb port does not work
Usb port does not work
  • LG Master
  • 1,527 Answers
Hi there is a video on youtube showing you how to enable you to use the usb hope it helps
regards
shaun
Posted on Mar 17, 2014
SOURCE:
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
Hello I'm finally back again I got a customers LG tv Model #37lg30 it does not respond to the remote the buttons on then side alow us to operate the tv I tried the remote on another
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
Mar 23, 2012 | LG 37LG30 37 in. LCD HDTV
HMDI Conection
HDMI port on TV could have bad connections....happens sometimes when plugging and unplugging cable...machine soldered....bad weld!!!
May 19, 2010 | LG 37LG30 37 in. LCD HDTV
What is the tv code for 37lg30 tv
Most preset codes are 1234 or 0000 or 5555 and 8888 these are not srevice codes
Oct 08, 2009 | LG 37LG30 37 in. LCD HDTV
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
LG 37LG30 has stopped auto adjusting to screen format.
Try restoring to factory settings for everything(I believe there is an option there in one of the options menus). Double check to then see if it's set to set by program.
If that fails to work you may be having a bad main board issue if it is the TV. Make sure it isn't your cablebox being stupid, though.
Feb 15, 2009 | LG 37LG30 37 in. LCD HDTV
LG 37LG30 37 in. LCD HDTV Logo
103 people viewed this question
RONALD CARTER JR
