Washer is broken - I want to stack the next set - but the dryer is only a 2 yrs old
SOURCE: Dryer will not dry - drum will not turn
Just happened to mine also. The problem was that the Idler Pulley came loose from the drive belt. There is a switch on the idler pulley so that if there is no tension on it, the motor will not start and you will have the symptoms you describe. To reattach the Idler Pulley, remove the back plate surrounding the dryer exhaust. This will give you access to the Pulley. If the belt broke (unlikely with a new dryer such as yours), the fix is more involved. This dryer is the same as the Maytag MDE6700 - you can do a search for a service manual for that model and you can see the details. Hope this helps.
SOURCE: t5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Testimonial: "very very good"
SOURCE: AMANA DRYER MOD # P
To open that dryer ya need to first remove the top by removing the screws in the rear of it,then remove the control panel...behind the control panel are screws that hold the front panel to the cabinet.
this tip i wrote will help ya to determine why its not heating...after disconnecting the front panel it can be letf connected to run the dryer to see whats happening as far as the igniter not coming on or whatnot
Here is that tip http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
