I lifted the receiver and entered 42 that took care of the problem. I happened to see the suggestion on this sight. Our phone stytem does not have the feature button. We are still having problems with the MIC light being on, and are not sure how to get that off.I lifted the receiver and entered 42 that took care of the problem. I happened to see the suggestion on this sight. Our phone stytem does not have the feature button. We are still having problems with the MIC light being on, and are not sure how to get that off.
If you have a dtu phone than you have a feature key. Press feature than 1 turn the mic on and off. If you turn the mic off, people cannot hear you when using the speaker phone.If you have a dtu phone than you have a feature key. Press feature than 1 turn the mic on and off. If you turn the mic off, people cannot hear you when using the speaker phone.
you probably have an ext unit please try the following steps To set the time, Press FNC then 9 then # then set the hr and mins using number keys Use RECALL button to set AM & PM Press FNC again to set. Good luck and best regards John
Depending on the type of NEC system the function can change. Try pressing the feature key while in idle mode, dial access code 69, then press the feature key again.
To Set: Do not lift handset, Press FNC button Press the desired “One Touch” Key Enter number to be stored (remember”0” for external numbers), Press FNC button to save To Dial Lift Handset, Press desired One Touch key
To Set: Do not lift handset Press FNC button Press the desired “One Touch” Key Enter number to be stored (remember”0” for external numbers) Press FNC button to save To Dial Lift Handset 8 Press desired One Touch key to dial
it worked
