Is it normal for the red light to blink while in off position
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
SOURCE: Blinking Lights
I had this EXACT same problem. Blinking blue light and the hard drive never powers on. VERY frustrating...I have a home studio was in danger of losing over a year's worth of original music. However, this problem has a solution which I read about on this site:
"The problem was with the power source not the actual drive so I ended up pulling the drive out of the case and purchasing a new case from Newegg.com. It now works fine and only cost about $30 to fix."
This is EXCELLENT advice and FixYa is the only place I read about this solution. Though I'm no newbie with computers, I certainly had never swapped out an external hard drive. But, in 30 minutes for about $30, this problem is TOTALLY SOLVABLE. I went to newegg.com and ordered this product:http://www.newegg.com/Product/Product.aspx?Item=N82E16817106095
an external Azio hard drive enclosure. Because I always used Firewire hard drives, I got an enclosure that accepted Firewire---however, many others are available with just USB 2.0. Following the directions that came with the enclosure, I removed my blue-light blinking, non-functional hard drive from its enclosure and placed it into the Azio. Now, the unit is working fine. No datawas lost and the Azio drive seems to be working properly.
THIS IS A FANTOM HARDWARE PROBLEM---NOT SOFTWARE PROBLEM! I encourage the MANY people who have complained about Fantom drives and gotten no assistance to try this solution and avoid Fantom in the future.
To whoever posted this solution: thanks a million. You made my day.
www.ediesedgwick.biz
SOURCE: Status Light is red and blinking - Laser Printer
it means that one of the componets in the printer need replacing it could be the waste toner container. have a look at the on screen display that you get when the printer is operating
to access in windows XP go to the clock corner of your screen
you will see icons
find the one that is for the clp300 click on it and the on screen display will appear
look at the informaton and it should tell you whatt is wrong
SOURCE: coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
