How to set time zone and time set on a BAR339 PA.
SOURCE: Oregon Scientific Stark clock resets itself to PST.
-Press SELECT once and time number should flash.
-Press and hold SELECT and it will enter settings mode for the clock.
-At the bottom of the screen next to the moon phase you should now see PST time zone.
-UP and DOWN keys will change the time zone.
-Press SELECT and other clock settings can be changed.
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
SOURCE: Oregon Scientific Model 323a--Atomic clock...the
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
