Question about Psi 2500 Mobile Pressure Washer 5hp Honda Engine
Replacing spark plug need gap
What is the spark plug gap
NEED SPARK PLUG GAP FOR 9BSXS 190-1VH
The gap is .040 and is pretty much a standard gap.
May 17, 2017 | Cars & Trucks
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Need to replace sparkplugs on 2002 ford escape
well replace spark plugs is not a hard job,when replacing spark plugs, good time to replace plug wires also.you need to replace one spark plug at a time so you wont mix up firing order. you need a spark socket, torque wrench, 3/8 ratchet wrench, 3/8 short and long extensions,you need a spark plug gap gauge.spark plug gap for 2.0 engine 0.051 the 3.0 engine spark plug gap is 0.052 - 0.056. just follow spark plug wires they will lead you to the spark plugs.warning wait until engine cool down first because removing spark plugs from hot engine could damaged the aluminum heads,use compressed to blow away debris before removing spark plugs keep debris falling into the cylinders.wear safety glasses if you use compress air and use small amount anti seize compound to the spark plug threads.good idea slip a short length rubber hose over the end of spark plug to use as a tool thread it into place.reason i use piece vacuum hose it will grip the spark plug enough to turn it, but will start to slip if the plug begin to cross thread.when installing spark plug, it should turn at least few times if spark plug start tighten before 1/4 turn thread cross threading need to back off start over dont keep turning you will stripped spark plugs threads in the head also damage spark plug threads, so be careful, good luck with job.
Aug 26, 2012 | 2002 Ford Escape
Misfiring after replacement of spark plugs and wires
If it wasn't misfiring before. Make sure you have the proper gap on the spark plugs. Make sure you have the wires connected in the correct order. If you have the old wires, you may want to end up trying those one at a time to make sure you don't have a defect wire either.
Thank you,
Lee
Mar 04, 2011 | 1994 Ford Escort
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
When do the spark plugs need changed
Spark plugs like any electrical device become worn over time. Spark plugs also work under extreme condition. The use of cheap fuels will leave deposits, poor maintenance, bad air filters, old plug wires, all these items can cause a spark plug to fail or not perform at its peak level. Also spark plugs use a gap or Electrical bridge that is used for high voltage to arc across. The larger the gap the hotter the spark until you reach a point that the coil can not bridge the gap and then you get a misfire. Also when a plug gets deposits from either oil, poor fuel, carbon this will shorten the gap and cause a weaker spark resulting in poor performance, wasted fuel and engine dieseling or Run on after the ignition is turned off.
These are the simple reasons for spark plug replacement.
Jul 19, 2010 | 2005 Dodge Caravan
Best Spark plugs for a 1993 GMC Jimmy SLE Vortec V6 - Fuel Economy help!
AC 41803 Drivetrain:Four Wheel Drive;
@Gap .045" This is a Platinum High Performance Spark PLug
Option : ASP AR25
EngineVIN:W;
@Gap .045"@ High Performance
Stay away from those Gimmick Spark Plugs , they are just more money for nothing. A good platinum spark plug is all you need, the key is to gap it correctly to your application...
On GM products Vin # W it is .045 plug gap
On Gm products Vin # Z it is .035 plug gap
You will not have huge gains in fuel mileage from replacing spark plugs except to say that if your old ones are just extremely bad, there is no magical spark plug with extra mileage manufactured into it.... Hope this helps...
Aug 24, 2009 | 1999 GMC Jimmy
How to replace sparl plugs on a Jeep Cherokee?
Hello, I hope this info helps...(subytech1)...REMOVAL
In this engine, each individual spark plug is located under each ignition coil.
  1. Prior to removing spark plug, spray compressed air around base ofignition coil at cylinder head. This will help prevent foreign materialfrom entering combustion chamber.
  2. On this engine each individual ignition coil must be removedto gain access to each spark plug. Refer to Ignition CoilRemoval/Installation.
  3. Check condition of coil O-ring and replace as necessary.
  1. Inspect spark plug condition. Refer to Spark Plug Conditions.
CLEANING
Theplugs may be cleaned using commercially available spark plug cleaningequipment. After cleaning, file center electrode flat with a smallpoint file or jewelers file before adjusting gap.
CAUTION: Never use a motorized wire wheel brush to clean sparkplugs. Metallic deposits will remain on spark plug insulator and willcause plug misfire.
ADJUSTMENT
Setting Spark Plug Gap - Typical
Check spark plug gap with a gap gauge tool. If the gap is not correct,adjust it by bending ground electrode. Never attempt to adjust gap bybending center electrode.
INSTALLATION
CAUTION: This engine is equipped with copper core groundelectrode spark plugs. They must be replaced with the same type/numberspark plug as the original. If another spark plug is substituted,pre-ignition will result.
Special care should be taken when installing spark plugs into cylinderhead spark plug wells. Be sure plugs do not drop into plug wells asground straps may be bent resulting in a change in plug gap, orelectrodes can be damaged.
Always tighten spark plugs to specified torque. Over tightening cancause distortion resulting in a change in spark plug gap or a crackedporcelain insulator.
  1. Start spark plug into cylinder head by hand to avoid cross threading.
  2. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  3. Before installing coil(s), check condition of coil O-ring andreplace as necessary. To aid in coil installation, apply silicone tocoil O-ring.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
Aug 07, 2009 | 2000 Jeep Grand Cherokee
Do not know where spark plugs are located in motor
the spark plugs wires are directly located on top of the engine and the spark plugs are down inside the holes in the valve cover itself. I believe there are also 2 coils on top of the engine, which hide two of the spark plug wires which are attached directly to the underside of each coil, remove the coil pull it upward carefully and you will find the spark plugs for those two in the hole underneath the coil for each one. If you decide to replace the plugs, make sure to check the spark plug gap even if they tell you they are pre-gapped as pre-gapped spark plugs are usually gapped for more than one particular car and it may be incorrectly gapped for your specific vehicle. If you decide to also replace the spark plug wires, you will have to purchase the spark plug wires for the underside of each coil seperately because most local auto parts stores only sell 2 spark plug wires in the set that go onto the non-coil attached wires and plugs, and you have to purchase the coil spark plug wires seperately. So all in all you should have 4 spark plug wires, 2 that attach directly underneath the 2 coils, then 2 regular type wires that run to the other spark plugs. If you look at the valve cover and see the wires, you will see what i am saying better. Just don't forget to ask the autoparts store the spark plug gap recommended for you car, and adjust the gap on the plugs as needed. good luck.
Bren H.
Sep 19, 2008 | 2000 Mitsubishi Mirage
Psi 2500 Mobile Pressure Washer 5hp Honda Engine Logo
64 people viewed this question
Top Psi Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Psi Tool and Hardware - Other Expert? Answer questions, earn points and help others
