Question about Yukon FF13011 Firefield 2.5-10x40 Riflescope with Red Laser
I purchased this scope from Centerfire Systems. It arrived on 2/14/2014. Unfortunately one of the mouning nobs didn't have any threads in it. I need a new mounting nob. I called Friday and was told you would call back. Didn't happen. Thank you, Leonard Minton
    Top Expert:
  • Yukon Master
  • 53,745 Answers
Fixya site doesn't do phone calls
any way if you got it in 2/14/2014 why did you not do somethinh about the problem immediately and not 4 years later
Posted on Mar 05, 2018
SOURCE:
Serial Number 5311256. When was this gun made?
Jan of 1985. Another Model 94. Great rifle!
May 17, 2016 | Optics
Releasing the bolt on a 270 semi automatic
Download the manual here. http://www.remington.com/products/firearms/centerfire/model-770/model-770.aspx
Nov 09, 2014 | Remington 85632 770 Sportsman Rifle .270...
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Elevation cap srew broke, Bushnell Banner, 20 yrs old 3x9x38
Take it to a well stocked hardware store and see if they have a screw that will work.
Aug 25, 2009 | Bushnell Banner Dusk & Dawn 3.5-10x36 AO...
Simmons Prohunter Model 517710 won't shoot a group
You SHOULD send it back. There is something loose inside the scope. Even the worst Simmons scope will get you to 2"-3" group. Also, when you replace it, you might want to consider their (or Nikons) shotgun scopes. They are built to with stand the power of the higher centerfire calibers and magnum shotgun shells.
Jan 23, 2009 | Master Heaters Simmons Master ProHunter...
Yukon FF13011 Firefield 2.5-10x40 Riflescope with Red Laser Logo
46 people viewed this question
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
