Your Radio is in auto Mode, you can deselect it by pressing any key except AutoKey. From below link download user manual and see page no.9. https://www.radioamatore.info/attachments/1241_TS-711_user_manual.pdf
SOURCE: my tv wont turn on all it dose is beep when i pluge it in
If you look on the back of the set, there will be a chasis # probably a CTC169 . These sets usually need to have the power supply repaired. These are great sets and have an awesome picture. There is a kit,I which is available to service technicians which will repair the power supply in most cases. If you can find a good local technician , they should be able to repair this problem for approx $125-150. if you have further questions pertaining to this set , I will be happy to advise you. I probably have repaired a coule hundred of these sets. This is one of the few old crt sets that are worth fixing. Scrivitron
SOURCE: Kenwood kdc-x859 just stopped working
This hapened to me also. I removed the power fuse to the radio and it reset itself.
This solved the problem for me.
