Sometimes the pad works several days,sometimes jus a few hours
SOURCE: Synaptics touchpad not working properly
Hmm give this method a try. Turn off computer remove AC power adapter. Remove the battery and press the power button for 30 seconds continuously. This removes the static from the system. This process is called as Power drain. This works in most of the cases. Good Luck !!!
SOURCE: hp laptop suddenly turns off
well..the battery is either unhappy(needs a full recharge) or it's dying..or it's an internal charger issue.
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
SOURCE: Acer laptop problem: Hard disk/motherboard problem
Try 2 things....1) replace the IDE controller cord or the SATA cord whichever applies. If this doesn't fix the prob try downloading latest mobo updates as well as any Acer updates for your specific model. Let me know if any of this works.
Thx
