Question about Nokia 6630 Cellular Phone
New sim insert
New sim not work
New sim card and new phone. But nothing works. Is there anything regarding unlock
First ensure through your network provider that the new SIM card has been activated. If not wait for the activation to complete. Everything will be fine.
If the activation has been completed and still if it doesn't work, Insert your SIM card into any other active mobile phone and check whether it works with it. If it doesn't work there is some problem with your SIM card. Contact the seller where you bought your SIM card. If it works fine with the other phone, then there must be some problem with your new phone's SIM port.
Try inserting any other active SIM card to your phone and check whether the SIM port of your mobile phone is fine.
Also make sure that the new phone is free from network restriction or locked to same network of your new SIM card. If it has been locked to some other network, you need to unlock your device.
To unlock a mobile phone from network restriction, you need to enter it's unique unlock code. You can get an unlock code from the respective network provider or from any private service. For example, If you have a Blackberry phone, You can visit UnBBLock.Com to get the unlock code. If you have any other model phone, visit http://www.mobile-unlocker.com/ to get the unlock code at affordable cost with easy unlocking guide. Good luck.
Jun 03, 2014 | Cell Phones
My new sony ericsson c 510 phone is brand new.i am used it 2 month.last week some times display inactive sim and not work phone.some time work calling the phone cut the line beep tone.display inactive sim...
Inactive sim is usually related to your SIM Card, you should try reinserting your SIM card again, to see if it works, or simply insert your current SIM card into another phone to check if there is any service. should both failed. It should be your SIM card problem, you can contact your service provider or carrier to have a replacement SIM.
Mar 12, 2011 | Sony Ericsson Cell Phones
I put my old sim card in my new phone then I got my old phone back working and put the new sim card into my a107 phone and it read sim crash
Try to reinstall you sim card.
If this does not work, install you sim card back into the new phone.
If the sim card works in your new phone.
The sim card is not defective.
Your a107 may not be working correctly.
Jan 18, 2011 | Cell Phones
WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card. Take it to a local dealer they should have a new SIM they will put your number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
Mar 27, 2010 | LG CF360 Cell Phone
I bought a new go phone and my old sim card wont work in it
Just go to provider, replace the old SIM CARD with new one. They will be give you the new SIM CARD with the same number ofcourse...
Jan 25, 2010 | LG Neon GT365 Cell Phone
I need a PUK code. At&T gave me one and it does not work. I even took out my sim card and put it in my husbands phone with the same puk code and it still does not work.
at&t has 2 puk codes per sim card but if that is not working u will just need to buy a new sim card and a at*t store can transfer your sim imformation from your old sim to the new one and new sim cards are $25+ tax
Jan 15, 2010 | Cell Phones
6085h restriction code unlock?
you have to ask your service provider.
Jul 13, 2009 | Nokia 6085 Cellular Phone
Phone not accepting a new SIM card
I think you have activated this sim only lock. This should be found under security menu. Try unlocking i first. If none works, you may consider flashing the phone if you need the phone working.
May 27, 2009 | Nokia 6270 Cellular Phone
HELP my new cell phones aren't working
you just need to get a new sim card for these phone and make sure to transfer numbers to new sim this is basically a sim problem when they get use to a phone there parameters are eched into the sim and then they only want to work with that phone
May 20, 2008 | AT&T Cell Phones
Nokia 6630 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
