Question about Pride Jazzy 614 Hd JAZZY 614HD
Everything works fine but won't manually turn off, but will time itself off.
    Scholar:
  • 90 Answers
There are two possible likely problems here: the joystick "key" or contact on the printed circuit board is bad/worn or the joystick is defective. The "key" is the rubber button pad that you press to turn the PWC on and off. This keypad is carbon embedded rubber that makes contact on the printed circuit board underneath. When these age or get moisture, the contact on the board oxidizes and the rubber becomes de-carbonized resulting in a poor contact when the key is depressed. Cleaning the contact with rubbing alcohol and a light scraping tool works sometimes. Replacing the keypad is a must.
If these don't work then you have a bad circuit board in the joystick. Either replace the joystick or the PCB within it. PCB replacement must be done by a properly trained electronic tech or Curtiss\PG Drives who makes the joystick.
Posted on Mar 16, 2014
SOURCE:
2008 Jeep Liberty
Possible solution - This happened to me and my battery was dead in my key fob and also I needed an ignition switch because a piece on it was broken which therefore wouldn't turn to start the engine.
Apr 26, 2013 | 2008 Jeep Liberty
The air con won't work. How do I fix it, everything seems to be set up fine. I thought all I had to do was turn it on and the air con would turn on, but it won't
Check that the master switch on the external condenser fan housing is turned on, it is a sliding button like switch.
Feb 25, 2013 | Heating & Cooling
Hi. Have problem with my Amilo notebook Pa 3553. The problem: if i turn off my laptop and try to turn on again, it starts but won't turn on the screen. I have to swich off and on multible times to get...
Could it be a loose connection to the monitor itself, check your hardware's integrity. If everything boots, try re-installing your graphics driver again.
Nov 03, 2012 | Computers & Internet
I have a vy series 2 ss crewman we changed the auto trans in it today but whilst taking out the old one we broke the speedo wire, we have taped it up out of the way for now but when I took it for a test...
with the more modern cars that have automatic transmissions, the ECM (cars computer) uses the information from the sensors (speedo, and others) to send a signal to the trans to change gears. you will want to splice the wires back together (assuming that the sensor itself did not get broken) if the sensor itself WAS broken off, then you need the replace it.
Nov 20, 2011 | 2004 Pontiac GTO
I have a Sony NSX-40GT1 that won't power on. You can hear the relay click after plugging in, and the red power led comes on, but when you push the power button it does nothing. Any ideas?
I'm having the same problem. Can anyone help. If possible i'd like to fix it rather than go return it. It worked fine for a while and then suddenly started turning itself off. Now every time i turn it on it turns itself off.
Jun 12, 2011 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
Pride Jazzy 614 Hd JAZZY 614HD Logo
83 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
