I can't record from tape via input mike jack
SOURCE: Is there a stereo input for the Dell Inspiron 1100 to record?
Yes, the input is stereo BUT you need to configure Audacity to do the stereo capture. Go to File > Preferences. Once in the preferences dialog, go to the third Drop-down menu, and change from MONO to 2-channel stereo. That is.
SOURCE: Inspiron 1525 records only left channel using keyboard of guitar
your musical instruments seems not supported by the audio card your using for your laptop. you need to have a higher end of audio card for the musical instruments to be recognize.
SOURCE: Can I record stereo via the mic input on my Dell Inspiron 2200
Try using Musicmatch Jukebox,it`s a great program for this and doesnt cost much..has to be pro version to record.You can choose both line and mic stereo recording as well as burn audio cd`s...lots of great features...good luck:)
SOURCE: Can I record in stereo via the microphone/line-in
The input-level from a (monophonic) microphone is MUCH less than the input-level from a device (cassette player?) connected to the (stereophonic) LINE-IN socket.
So, crank-up the slider, to amplify the input.
Make sure that you're connecting into the LINE-IN port, if you want to record in stereo.
SOURCE: I have a Dell Inspiron
If you go into your start menu, go to accessories, then click on sound recorder you can use that application to record only audio.
