I have HP Probook 6550b, I want to instal window XP on it, but i can't. is that laptop support window xp or some other problem is preventing to instal win XP
SOURCE: enable wireless on Hp probook
You can enable your wireless lan via quick launch button on the strip , when tapped it will show you blue light when disabled it will show you with orange light, if you see that light is still blue but you are unable to find any wireless network in network and sharing center
simply open network and sharing center > go to change adapter settings
right click on wireless network connection and select enable ,
now your wireless should work,
Feel free to contact us if you require more assistance,
Regards,
Bilal
SOURCE: fn+f9 and fn+f10 hot keys are not working on my HP
you dont say what version of windows your running , this file is for windows 7
ftp://ftp.hp.com/pub/softpaq/sp51501-52000/sp51993.exe
download and install that
SOURCE: How do I turn up
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
SOURCE: I have now Win XP
Hold down the Ctrl key and the Alt key then press the Del key. This will then bring up the Task Manager. Then click on Shut Down then click Turn Off.
This will then shut down your laptop properly.
SOURCE: sir I Purchased a new
my recommendation is that you should not switch to windows xp because now a days laptop are better compatible with windows 7 and as for the lower version of software that are not running try getting higher version because newer version will always have some improvement
This type of error occour when i try to instal ....
