Question about Jacuzzi Home
What cleaner gets the bad smell and crud out of jacuzzi jets?
Rainbow Waterfall
  • Jacuzzi Master
  • 719 Answers
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Posted on Mar 17, 2014
SOURCE:
co7196
  • 3433 Answers
SOURCE: smells like somethin died
Pour some chlorine bleach , not alot.in and let it circulate. You may want to clean the filter first.You are smelling a real dirty filter.
Posted on Jul 29, 2009
jasonmteat
  • 111 Answers
SOURCE: Jacuzzi jets smell like rotten eggs when turned on.
Any time you get a strong smell of rotten eggs it is due to a high concentration of sulfer in the water. Are you on well water? I would suggest using a cleaner like http://www.sani-bath.com/ to clean out your system.
Posted on Mar 17, 2010
Testimonial: "Thank you so much....I didn't even know that had products like these. I am ordering as I type. By the way, we don't use a well, but I'm sure it will"
  • 349 Answers
Need to run some cleaner through jets to clean out old water and mildew.
Posted on May 12, 2010
uspartscente
  • 719 Answers
SOURCE: How do you remove Jacuzzi Waterfall handles to get
On the top of each handle you will need a very small flat head screwdriver or something similar to "pop" the top cap off. Under that cap there is a phillips head screw so you can remove the handle.
Posted on Jan 12, 2011
uspartscente
  • 719 Answers
SOURCE: Need to know how to remove the handles on my
There is a cap on the top of square knobs that you have to pry off with a tiny thin blade. Under that cap is a screw that will allow you to remove the knob.
Posted on Jan 13, 2011
Is it Chitradhara Waterfall look more attractive and beautifull?
best experience is to go there your self and experience it
Jul 23, 2016 | Furniture
Is the waterfall inside a lake in Portugal real?
It is a 'spillway' an overflow tube in a hydro-electric dam.
  • VOTD: Waterfall in a Lake? - Joe For America joeforamerica.com/2016/03/votd-waterfall-in-a-lake It's not completely natural waterfall though, ... VOTD: Waterfall in a Lake? ... A waterfall inside lake! !!(Portugal).
  • A Waterfall Inside a Lake. - Chonday.com www.chonday.com/Videos/waterallake4 Video embedded · A Waterfall Inside a Lake. Near Guarda, Portugal you will find Cov?o do Conchos, a surreal looking spillway that is part of the Conchos ... A Waterfall Inside a Lake.
  • May 22, 2016 | Plumbing
    How do I replace the fuse on a rainbow vaccum?
    The D4 model Rainbow has a Thermal Cut Off
    This has to be manually replaced. It is attached to the Field 120v D4
    If this has blown, then most likely something is causing. The Armature Tall 120v D4 could be going bad.
    You can also speak with our technical support team Contact Us
    RainVac
    Jan 27, 2016 | Rainbow D4se Classic Canister Vacuum...
    How do I get bad smell and crud out of jacuzzi jets
    If you are experiencing a "smell" coming out of the water when you use the tub then you should use one of the products that are made for cleaning jetted tubs pipes.
    Here is a link to a site that carries those items. These will get rid of the nasty smell and flecks of bacteria when you use the tub too.
    Rod
    US Parts Center
    Mar 15, 2014 | Home
    What are waterfall braids?
    A waterfall braid is a type of braid that is similar to the French plait but it comes from the side of the head using only a small section, rather than taking all of it. It's called a waterfall braid as it has small sections of hair falling down loosely at the sides.
    Feb 14, 2013 | Health & Beauty
    Replace waterfall in hot spa
    possible bad relay for waterfall or pump to waterfall
    Feb 05, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
    Black flakes from jets
    It is biofilm growing inside your plumbing. The black flakes are most likely biofilm. Check out specific cleaners designed to remove that crud. The best is called OH YUK
    Apr 22, 2012 | Whirlpool Home
    Home Logo
    332 people viewed this question
    Top Jacuzzi Home Experts
    US Parts Center
    US Parts Center
    Mike
    john h
    Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
