Have loked at all the capacitors and resoldered. No joy. Checked the power suuply for dry joints. No joy. Am looking for a circiut diagram for the Power supply. Can anyone oblige? THANKS Brian
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
SOURCE: LG 42PC1DV. POWERS UP NO PICTURE NO SOUND
Hi Ryan, You are on the right track. It is the power supply board. Once you replace the power supply board, the unit will back back to brand new. Mike
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
SOURCE: Plasma Television won't turn on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
