The battery light doesn't mean you need a new battery it means that the battery charging system is faulty, that is the alternator and the voltage regulator, the lights are on because the system voltage is low, they will not turn off until the charging system problem is diagnosed and repaired.
I have 04 x type car turns on I put it on gear and a cranky noice and the car dont move crank gets more loud if I try put it back on park it grinds loud so I have to turn off the car just to put it on park
On the front of the droid there is a red button that lights up when turned on & turns off after a couple of seconds, depress that button to free up the droid. Its called the wheel lock control button. That should free up your R2
My
2007 GMC Yukon will not start in cold weather. When I turn the key over
the lights/dash controls come on, but the engine does not turn over at
all. Nothing. Put a new battery in and still does it. It is a random
occurance. Would not start for two days this week so I had it towed to
the dealership and the next morning it starts without the service dept
doing anything??? Bring it home and two days later it does it again???
Any ideas?
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds. A blinking light can mean something is wrong with the power, not enough or something else. If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
