Samsung DVD-Homecinema-Sound-Package  HT-Z110R black Logo
A
Anonymous Posted on Mar 15, 2014
Is samsung series 5 tv compatible with E8200 sound bar
How to turn solo sound bar on without remote solo sound bar 15 series 2
Hi James-
I found this link regarding Bose Solo Sound Bar 15 Series II.
https://www.bose.com/en_us/products/speakers/speaker_accessories/bose-rc-pws-iii-universal-remote-control.html#v=rcpws_iii_universal_remote_acc_black
This remote is compatible with all Bose Solo TV Sound Systems.
Hope this helps.
Samsung series 5 picture with no sound
Hi Faldie, so you comment on your Samsung Series 5 TV, the backlight is wrong
To make a correct repair, you must replace all the LEDs
It is a specialized technical service
Greetings Franco Dosil
My Samsung tv model number UA40C5000QF does not have a hmdi arc port and we have bought a Samsung sound bar but it cannot be connected as it does not have that port
Your sound bar can be connected to the UA40C500QF. Get an appropriate audio cable based on the sound bar. You'll either need a optical digital audio cable or an analog audio cable with a 3.5 mm plug on at least one side. (If your sound bar has an AUX input, then a 3.5 mm to 3.5 mm M/M audio cable is appropriate. Otherwise, you may need an RCA (M/M) to 3.5 mm audio cable or some sort of RCA to 3.5 mm adapter (F on one side, M on the other).) Connect this cable to the audio out on the TV (headphone or digital audio) and the appropriate audio in on the sound bar.
Set the sound bar source to the chosen input (Aux or Digital In (D.In on some systems). Next, set the TV to use External speakers. This is in the Audio sub-menu. The volume will now be controlled by the sound bar volume control.
You can still use the HDMI cable (HDMI out to any HDMI in on the TV) if you want to use the TV screen when changing the settings on the sound bar. Just change the TV source to that HDMI port with the Source button on the TV remote or on the TV (the left-most button on the front panel). Then change your source back to the video signal for the TV to view items connected to the other HDMI ports. If your sound bar has an HDMI input, you would similarly use set the TV to the sound input to watch that source.
I hope this helps. See the manual for the UA40C500Q for the details on setting the speakers to External speakers. The manual is available on the support page: https://www.samsung.com/au/support/model/UA40C5000QFXXY/ . The current link to the manual is http://downloadcenter.samsung.com/content/UM/201003/20100316163048500/BN68-02727A-00Eng-0225.pdf .
I Have a SAmsung TV T 220HD and need a sound bar as my hearing is now very bad. I am 76 I have looked at PanasonicSCHTB20 or 527 will they fit??? would I need cablesThank you
Yes, that sound bar appears to be compatible with your monitor/TV. Your options as to cabling are 3.5mm audio cable or digital optical audio cable. The digital optical will definitely have better sound.
Cannot figure out how to connect my new sound bar to my older TV
Use a high speed HDMI cable form the TV to the sound bar. HDMI cables carry sound as well as picture signals. Refer to your TV's user manual http://www.hdtvsolutions.com/pdf/52527-62528.pdf
and the Samsung product support page http://www.samsung.com/us/support/owners/product/HW-F450/ZA for assistance
SAMSUNG PCL5415
If the sound on your DLP TV is out of sync with your picture and the TV is not connected to a home theater system, a Samsung technician can adjust the sound sync function on the TV so that the sound and picture are in sync.
To arrange a service call to adjust the sound sync function, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864).
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
