Sanyo DS24205 24" TV Logo
A
Anonymous Posted on Mar 15, 2014
Can i plug my computer monitor into my dvd player?
Can i connect a dvd player on it
only if your dvd player uses dsub or dvi connections. so prob not.
(ive never seen it) dsub and dvi are comouter connections.
youll need a dvd player and monitor with the same ports.
hdmi or svideo are you most likely options (depending on what port the dvd player has. it may only use RCA which is rare on computer stuff)
I replaced internal cd player and now the monitor wont work
CUANDO MALCO EL DOS SALEN RALLITAS COMO PUEDO INTALAR AROBA
I have tried to hook up the monitor to the dvd player and all I get is grey and red on the screen
Most of the time its one of two things the cable needs to be replaced if you can plug into computer and it works that rules this out Second the connector on the dvd is bad this is the most occuring problem. I would try someone else's dvd player and see if it works.
Can i connect a dvd player to a dell e173fpf monitor with a scart to vga adaptor/cable?
You can with an RCA to VGA converter device (Amazon has it for $45 S&H), the AV cables of your DVD player and a pair of amplified speakers. Connect the yellow RCA video cable to this device then your monitor's VGA cable to the device. Also plug in the red & white RCA audio cable to both the device and to your DVD player. Finally connect your speakers to the DVD player ad your'e all set!
How do i connect a dvd player to a computer monitor?
your dvd player has left audio output . this should be white. aso it has a right audio output this should be red ,both of these are called rca females . note you have to have a cabel with two rca mails and a 1/8 inch stereo mail on the other end. this 1/8 inch plug will go in to your computer input . the other two rca will plug in two your your dvd player and thats that. this will work for you i am a electronics technition . good luck and enjoy your movies
Black and White Video input
Check your plug that plug into computer, one of the legs has bend.
Dvd
Most laptop computers only include an output to connect an external monitor, not inputs for external sources, so the simple answer is no. If you want to be able to play DVD's on a laptop that doesn't have a DVD drive, then you can get an external USB drive and plug that in.
Hope this helps.
Car dvd player replacement to match headset monitors
yes you can aslong as the dvd isn,t a factory fitted one by your car maker etc
most dvd players in cars just have the standard red ,white and yellow phono outputs which plug straight into most headrests monitors but again it depends on what make is the cars dvd player and also what make are your headrest monitors ?
Input video to nec 1740cx-bk lcd monitor
If you are trying to use a computer monitor to watch a DVD, you probably won't have much success unless your monitor accepts the RCA plug. I have found the VGA adapters to RCA plugs will not work in this manner.
Component conecters
alright...those are Component Connectors...your DVD, and VHS will not work with that Monitor at all.
The Best and Cheapest Option...is to Buy a "Modern" DVD Player...which almost every single one Has Component Connectors.
On your Current DVD, VHS...ECT. The Red and White is Audio respectively, and the Yellow is the Video.
On a Component However the Red, Blue, and green...are all Video. You will need to use your "Current" Red and White Audio Jacks from your DVD and VHS Players on your New Monitor, and New DVD Player.
As Far as VHS is concerned...if you Buy a DVD/VHS Combo...you should have a S-Video Jack on Both the Monitor, and the DVD/VHS Player...Buy a S-Video Plug.
With that you will be able to watch both DVD's, and VHS Tapes without issue
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
