Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter Logo
A
Anonymous Posted on Mar 14, 2014
How do you reset the light for the filter to show when new one is needed
Replaced filter. Why is red light still showing?
The filter light is controlled by time interval. Not by how much water that has gone trough it. Your refrigerator does not know that it has a new filter before you tell it that it has. I dont know the brand of your fridge. But there is a reset filter button. Look at the attached picture for a example. On this fridge this picture has to pressed and keep pressed for 10 seconds to reser filter light from red to green
1helpful
2answers
I changed the filter but it is still showing a red light.
Most have a reset button you have to push for 3 second some you press the lite switch 5 times
How to reset the order filter feature
Good Afternoon Friend,
I understand that the order filter light is showing on your Frigidaire refrigerator, model# DGHF2360PF, and you want to know how to reset it. What you will need to do is press and hold the Water Filter button on the Ice & Water Dispenser control panel for three seconds. When the display changes from Red to Green, the status has been reset. I hope this is helpful.
-Best regards-
WP
How do i turn off the light that shows i need a new filter after i replaced the old for the new.?
read the box that the filter was in and it will tell you,you have to hold in two buttons i believe it's the light and lock pads for like 5 seconds and it will reset.
2helpful
2answers
The light saying to change the filter came on so I bought a new filter and put it in and the light is still on. Is there a reset switch some where ? Ive never had this happen in the past. I would just put...
  • How to reset the 'change filter' indicator light, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
3helpful
2answers
My indicator light is showing MAINT. REQ even though i already replace new oil and filter
you need to reset it. by having key turn off and pushing the trip reset button on the dash. then turn key on and the light should blink and go out after a while keep holding button tell it goes out
Reset change filter light
Push the button in, that you will see, when you open your refrigerator door, hold it for about 10 sec. then let it go, it will turn green, If the light comes on, an says you need a new filter. That is not always true. do the same thing befor buying a new filter, to make sure you need a new filter.
Reset fap02
I have this machine. Change the filter. Turn back on. The "reset" button on the top of the machine is very narrow. Place your fingernail into that Reset button and hold till it starts to blink red. After about 3 blinks the light will go off. The reset button is now reset for the new filter.
1helpful
2answers
Filter light status
Please verify the model number for your fridge, as the description shows a Frigidare 24" dishwasher.
With the model number and you providing the different buttons on the front panel, I can provide you with the button sequence to push and hold to reset the filter light.
While waiting for the needed info for an exact solution, you can try this:
If you have a "light" and "lock" button, push and hold them together for several seconds, the filter light should go off or change back to green.
If not, please provide me with the brand and model number for your fridge so I can give you the correct procedure for resetting the indicator light, by responding back with a "comment".
Hope you find this Very Helpful and best regards!
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Not finding what you are looking for?
    Top Frigidaire Refrigerators Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    john h
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
