Kitchen Appliances - Others Logo
Anonymous Posted on Jun 13, 2009
Heath Zenith #SL-5316 Motion detector light what are settings?
Have Heath Zenith #SL-5316 Motion detector light, but no instructions. What are the settings for this unit? I can send a photo of the controls, if you tell me where to send it.
The light quit working and I got a replacement light set, and want to move the motion detector to the new light unit.
Thanks
Norm Johnson
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2866
Points
Go to http://www.heath-zenith.com/search.cgi (displays as HEATHCO webpage) and search for SL-5316 ... choose manual below.
See http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Thanks
Lights flash on and off
Very common issue with motion sensing lights. You can either replace the light sensor which is available at most hardware stores or you can disable the motion sensing feature and just have an on-off light. To disable the sensor, (turn off the power!) unscrew and remove the light sensor (it is the reposition-able box under the light.) It depends on the particular light, but you usually just match up the wire coming into the light from the house and the wire from the bulbs and connect them with a wire-nut.
3answers
The LED flashes, but the lights won't come on. Do I need to install a light shield. The sensor is mounted in a well shaded area 10 to 12 feet above ground. There are landscape lights beneath the sensor are...
There are settings on the sensor itself. Should be a dusk to dawn setting that will keep it off during those times and then function at night. as far as not working I would first suggest setting the sensitivity. Disrupting to power could have reset this.
1helpful
2answers
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
I need a download for the instructions that came with a Heath/Zenith SL-4142-B motion-sensing porch light.
I was looking for the exact same thing today and found out it is the same as the SL-4152-B instructions:
http://heath-zenith.hcents.com/data/manuals/595-5578-09.pdf
Hope that helps. Enjoy.
Jan 02, 2011 • Vacuums
I have a Heath Zenith outdoor coach light model 4160. The motion detector switch failed after about 6 months. I don't want this problem again so please tell me how to bypass the motion detector so that the...
By pulling it apart and following the circuit path it should be fairly apparent how to 'bridge out' the faulty PIR sensor.
If it is not, or you are not sure, then (no offence), you really shouldn't be playing with it. Some units are transistor bypass and some are relay. Cheers
10helpful
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
4helpful
I have a sensor that stays on all night when the
Your motion detector is based on infrared or heat sensing technology. Moving air or wind will make your unit more sensitive to false alarming. Here are a few things for you to check: 1) make sure your unit is sealed. Any holes or openings in the unit's casing will affect operation. 2) you may need to readjust the unit's sensitivity. There may be an adjustment pod or jumper inside the detector to reduce sensitivity. 3) make sure the unit is mounted securely. If the wind causes the detector to move, even slightly, this could be the cause of your problem.
28helpful
3answers
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
