Sharp SJPT640RS Top Freezer Refrigerator Logo
A
Anonymous Posted on Mar 14, 2014
My sharp freez not cool - Sharp SJPT640RS Top Freezer Refrigerator
Jayesh Panchal
Level 2:
Sergeant:
Champion:
  • Sharp Expert 280 Answers
  • Posted on Mar 03, 2015
Jayesh Panchal
Sharp Expert
Level 2:
Sergeant:
Champion:
Answers
280
Questions
0
Helped
124806
Points
621
You can checked error with pressing select button for 5 second while Ref door open.
If any defect in your ref error will display.
2answers
I have a Sharp Fridge-Freezer, model SJ-F78SP-BK. The Fridge compartment freezes. If left on overnight, everything will freeze as if it had been left in the freezer. Freezer is working fine.
please increase the temperature in the fridge portion of your fridge as it sounds like you've set that compartments temperature too low.
Thank you.
I plug in the cable/antennae wire and it freezes up. I can't change channels or anything. if I unplug it it changes fine, then of course I can't watch tv. I have a sharp lc-s3sb23u.
See if Sharp's customer service still walks customers through what is called an INIT or factory reset. 800-BE-SHARP. Make the television do what it does when it freezes up and then call. You might just need to scrap the television because if you need another main board the part alone will cost around $600.
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Why is my Sharp 32 inch 32sb28ut freezing up on any channel we put it on.
If you have a HD antenna hooked up to it and it has a low signal it will freeze up allot
Our lcd cannot switch on properly..must waiting unting half hour..
The power of the set seems to stabilise after the set is put on and then only triggers. So to confirm on this remove the back cover and heat up the power section, the controller section, the processing stages, till the set power up then confirm once again to allow it to cool, use a freeze-it spray to enhance the cooling. Once you pin point use a soldering iron to heat the speciific component to confirm, then replace. It can be even dry soldering , if so do a touch up job . Do it carefully without bridging any circuit. Good day
8helpful
Sharp lc32p50e, picture keeps freezing, sound ok. text hold symbol appears at same time as text freeze. any ideas?
try using the menu, and turn off the 'demo' mode ... this by default has a freeze setting .... hope that works
1helpful
No sound at all!
I agree with everything that they are saying.
Most tv companies under design the cooling needs of the flat panel TVs. I had to fix a few TVs this way that had similar problems. Mostly with the picture on TVs freezing up because of the poor cooling design for the motherboard processor. I would give their solution a try before replacing circuit boards.
Top Sharp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
