RCA D52W19 52" Rear Projection Television Logo
Posted on Mar 15, 2014
Does the high voltage wire in my rca rp tv come off the transformer or off the crt tube?
5 Related Answers
Anonymous
  • 317 Answers
  • Posted on Oct 19, 2007
SOURCE: Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Anonymous
  • 61 Answers
  • Posted on Mar 30, 2008
SOURCE: RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Anonymous
  • 5138 Answers
  • Posted on Feb 13, 2009
SOURCE: power ligt blinks twice no high voltage
CK capacitors cp150 cp114 cp120 if cp150 is puffed up on top it is bad so replace all 3 caps.2200uf 16v and two 220uf 35v
Anonymous
  • 1779 Answers
  • Posted on Jul 12, 2009
SOURCE: I have an RCA P61926 62
Just unhook the leads and away you go..........................
phil duncan
  • 17 Answers
  • Posted on Sep 01, 2009
SOURCE: RCA 52in. Projection TV D52W19B does anyone
How do you know the flyback is bad
1helpful
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
2answers
When I turn it on, it makes a buzzy noise but nothing else., no picture or tv sound.
The set has a high voltage problem, "the flyack transformer is defective" It generates the high voltage in the picture tube and with the help of the video circuits it produces a picture. It is not cost effective to repair the tv, cheaper to replace.
1helpful
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
1helpful
Tv picture is all black with sound
the high voltage circuit,more likely the flyback transformer is not generating high voltage to the tube.
3helpful
4answers
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
My tv doesn't come on but it acts like it want's to
It ur high voltage is dead.The FBT,the flyback transformer it dead.The big block of plastic with a red wire with a cap hook to ur CRT(tv tube).That thing it dead.
Does not turn on it lights and buzzes then goes out
Ur high voltage transformer is dead or cold soldiers.The FBT(The block of plastic that have a red wire that have a cap that hook up to CRT(the tv tube).
My Model # F36669, about a 5 year old 36 inch (non flat screen) RCA T.V. is popping loudly in back and turning off. I looked in back and noticed the popping noise is a short or something that is causing an...
That my friend is the high voltage transformer with a tiny pin hole allowing the high voltage to arc to ground. The red wire going to the picture tube is carrying 30 thousand volts to the anode connection on the CRT. This is not a consumer replaceable part as the CRT can retain healty voltages even when off. Refer to a local TV technician.
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
1helpful
Rca Hd52w58 electrical short
Just replace it... it is called the High Voltage Splitter. One red wire is the high voltage input from the flyback (high voltage) transformer, 3 red wires are the high voltage outputs that go to the 3 picture tubes and the red wire by itself is the focus wire going to the focus block. Does your splitter have a small PC board on the side of it? What is the exact model or chassis number of your set? With that info I can give you the RCA part number of the splitter which makes ordering it much easier.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
