One of my turntables only has sound coming out of the left speaker... its a sl-1210mk2
everything is plugged in...
One of your phono leads ether red or white is nakered.plug them in one at a time and see witch ones workin,then youll no the dodgy one.when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Check the pin conections on the arm and headshell sometimes these get a film and will lose contact it may not be this but its a easy check! Rees repair tech.
Try cleaning the phono cables, if not then...then replace them...if the problem still continues to persist...then i would advise either lookin into it, as in opening the deck up...and loooking if the phonos and ground are loose inside, or take it to a servicer, they will not brake easily so im guessing its a fixable probelm
