The starter just spins also have new battery
SOURCE: parts for a honda lawnmower hrx 537
It would depend upon WHERE in the world you are located but you should be able to contact your nearest Honda Mower dealer or do an internet search for
>> "hrx 537 honda parts" << and it will return quite a few places both on-line and in-person place where you may purchase them
SOURCE: Have a zforce 44 with
how much voltage does battery have? should show 13.2 to 13.6 volts....
SOURCE: I am having to replace
Your answer can be found at the link below on page 44. This will walk you through removing the cable and the settings for adjustment after replacement
http://www.hondapowerequipment.com/pdf/manuals/31VH7001.pdf
SOURCE: Honda mower engine oscillates when idling. Check it out: http://www.youtube.com/watch?v=HbmtcyPR2DM
The carb needs to be cleaned. The main jet and nozzle are the areas to pay attention to. The main jet screws into the carb in the same spot that the float bowl screw goes into. The nozzle sits above that and if you tap the carb (carefully) on the bottom once the main jet is removed the nozzle will drop out. Use a small piece of wire to clean all the small holes in the jet and nozzle. Make sure they are open and free of clogs. This is a common problem with all small engines.
