Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
SOURCE: My Samsung LE40A457 keeps switching
caused by the front customer switch assembly, just disconnect from inside and then use remote to tur on etc
SOURCE: Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
SOURCE: When i turn my samsung 50, no pic or sound 3 lcd lights keep flas
Hi friend,,,
welcome to fixya
Commonly for plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
