Computers & Internet Logo
Antonio Caggiano Posted on Mar 14, 2014
Netopia 7000 router
Hello everybody any idea what the problem might be please Thanks in advance for your help The problem is that all the ports are closed but in the NAT config they are enabled A port scan failed for example IP 123.***.x.*** is not responing on port
Donnie
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on May 05, 2014
 Donnie
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3909
Points
21
Try this website out they have just about every router out there listed Port forwarding the Netopia 2247NWG VGx router
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on May 01, 2008
SOURCE: Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
sixers_5
  • Posted on Jun 19, 2008
SOURCE: port forwading
http://portforward.com/
this site may be of some assistance
Anonymous
  • Posted on May 07, 2009
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Anonymous
  • Posted on Jul 15, 2009
SOURCE: ps3 setting up static nat
are you in ireland and with eircom?
Anonymous
  • 3 Answers
  • Posted on Sep 24, 2009
SOURCE: Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at [email protected] on add me i believe my ps3 thing is ADV_WARfighter
Good day! I have try to upgrade my Netopia 2247NWG-EIR firmware, but unfortunately my modem was hang. After power reboot my modem now not responding to any answer. But indicator of ethernet ports is light...
hello arthur, you wont need the eircom firmware you just need a firmware update for the netopia 2247nwg-vgx
go here fill out the details and download the firmware and update the router with it
http://www.netopia.com/support/hardware/firmware/updates.html?224xw
1helpful
Can I use more than one modem on my phone line to support multiple computers? Also, where can I obtain a list of modems compatible with a Netopia 2249n? Thanks
Hello
The short answer is no you really cant use multiple modems. The internet should come in to your home via the modem, then go in to a ROUTER. Many times the router will have 3 to 5 ports on the back to hook your other computers too. This means running cables. Another way is to use WIRELESS cards that you can find on the net or from best buy.
If your router does not have any extra ports you need to buy something called and ethernet switch. Again they come in 4 and 8 port models up to LOTS AND LOTS Of ports for big companies. You hook the switch in to the router, then hook the computers in to the switch.
I hope this helps you
1helpful
6helpful
AT&T Netopia DSL modem not opening ports for web servers
Try to open the required ports of your web server on your router.
Vpn
this is not so much a soloution but an idea!
from memory the netopia devices allow you to configure a dmz device by IP or MAC address.
I have had to do something similar but with a buffalo unit instead of your linksys. I ended up having to place the buffalo unitin into a dmz created on the netopia unit. before VPN tunnles were formed correctly.
2answers
Netopia 3347
no i dont sorry. if i had the two i could find out but i dont have access to any. sorry
Xbox live
Hello!
Yes, the netopia router will work with xbox live. you just have to configure some settings on your router.
To configure your router for Xbox Live try the following steps below:
step 1: Open an Internet Explorer page. in address bar type your router ip address, That should take you to the Netopia's settings page
Step 2: On the menu to left click Firewall, set it to Low and Save Changes
Step 3: On the menu to left click Expert Mode, then Yes, enter Expert Mode
Step 4: On the menu to left click Configure, then Advanced, then NAT
Step 5: Where it says Service Name, scroll the list down to Xbox Live Games, click Enable and then Enable again
Step 6: On the menu to left click Configure, then Connection.
Step 7: In main page scroll down to the UPnP and put a check in the box. then Save
It should then restart the Netopia, and when it comes back on in a few seconds your XBOX LIVE should be good to go. If you are still experiencing problems accessing Xbox Live your Netopia may require a firmware upgrade.
Connecting to computer
If there are additional ethernet ports (looks like a large phone cord port) on the back of your router, you can connect one of the ethernet ports on the back of the router with the ethernet port on the back of your computer, using a patch cable, which is category 5/5e cable with the large phone plugs on each end.
Or, you will need to purchase a wireless adaptor for your computer, preferrably a Netopia brand.
Top Netopia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
