Hi problem with the shutter closing when switched off and makes odd noise? Lens is covered by part of shutter when on help
You may disable camera shutter sound from camera setting option. There is more information about it here Olympus Digital camera user manual download owners pdf free user...
SOURCE: Lens will not extend
If you are dead careful you can take it apart to get to the lens mechanism. Before you do this however take the batteries out and leave it for a few days. This will help discharge the flashgun circuit and reduce the risk of electrical shock. The back cover will come off with a litlle persuation once you have rmoved all the screws. Make a not of which screw goes where though cos' theyr'e not all the same. After the back is off you should see the electronics. Don't touch any of the electronics until you are sure the flash circuit is safe! The first thing to do is to make sure the flash circuit is safe. First locate the flash leads. There are three one blue, one pink, and the other white. The actually connect on the other side of the board but you should be able to see them just above the top edge of the board. On the board near where they are you will see a lightining bolt in a triangle, that's a shock hazzard warning! The Capacitor is the big black cylindrical object on the other side of the board near where the flash cables connect. It has two leads which connect to the board about 1cm apart, just by the blue cable. They should be easy to spot as they are quite large compared to most of the other connections. Once you are sure you have the right connections you can do the scary thing, and discharge the capacitor. What you need to do is put the metal part of an *insulated* (Important that bit!) screwdriver across the two connections. Use an old screwdriver for preference, this can damage the screwdriver. Also, wear goggles or glasses when you do this, because you get quite a hefty spark when the contat is made. (It's as well to brace yourself for this, I do it quite a lot. It still makes me jump, and I ain't no girly!) By the way, this won't harm the camera, this capacitor gets discharged like this every time the flash is used. It just all goes into the flash-tube intead of through the screwdriver. That's quit a lot of concentrated heat, which is why it isn't good for shiny new screwdrivers! Make absolutely sure it is discharges before going on. You next will need to unplug the LCD connector and the menu 'paddle' before going on. The connectors used have two parts, one is a sort of latch. You need to slide the latch towards the ribbon to release the ribbon cable. (The latch is usally a differnt color from the rest of the connector. Theyr'e also quite small so get your reading glassed out!) Once this is done you shoud be able to free the elcetronics module, by removing one screw located centrally in the metal frame at the end where the lens assembly is. It comes in from the side of the camera. If you have got this far the fron cover should come away and you can see the other side of the module. The lens assembly is on the other side and is held in place by threee screws going through the board. One of these has a bit of red laquer on it. That's a message saying 'dont unscrew me'. So it's best not to. (You'll risk gettin dust on the sensor, and that's really difficult to clean up!) You should now bw able to see the actual lens motor, and some of the gears, and will be able to clean them a bit better! Note, don't go sloshing lots of water around, the lens assembly sits right on top of the image sensor which you don't want to get wet, nor do you want to get water in the lens. It won't dry off without leaving a stain. If you really need to dry it, use the purest alcohol you can lay your hands on. That will absorb the water, and so you can wash it away. The alcohol will dry a lot more easily then water and is less likely to leave a stain. Just make sure it's really pure! If that doesn't work, you will have to remove the lens assembly. First disconnect the motor cable etc. Then holding the lens in place remove the three screws, and carefully place the whole thing on a level surface with the lens facing up. Now carefully lift the lens assembly. Make sure that you do not distub the blue filter which fits over the sensor, and as soon as the assembly is free cover the sensor with a clean cloth to stop dust getting in. You should now be able to get at the rest of the gearing. After that all you have to do is put it all back together:)
SOURCE: lens open/close problem
I have two of these cameras for at work. Both have this problem. If you hold the power key and repeatedly press the top key (one that shoots the picture) or hold the power key and then press and hold the shot key the camera is forced to take a picture. The camera seems to be ok then. There is no damage to the lens, as the pictures and quality are the same. It is definitly a design flaw, and/or software issue. Good Luck, and keep trying untill it fixes itself.
SOURCE: statup problem
Hi there and welcome to FixYa.
Sorry no one has gotten to your problem sooner.
There is a problem with the lens mechanism. Here is what you can do, either:
A) Whack the camera on the palm of your hand as the lens is extending. OR:
B) As the lens is extending, pull it out and twist it. Don't be afraid of it, but...don't rip it out of it's socket either...LOL. Just give it a pretty good tug/twist.
It may take a couple tries, but that is what will help you. You just have to align the pins right with the track that they ride in. Let me know if you have any questions.
Rob
SOURCE: coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc" uploaded on site http://www.esnips.com/web/papputatiyasStuff It will be helpfull for you. Its is a step by step solution with images.
Regards
Mukesh
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
