go to settings-> do not disturb and make sure do not disturb is off, you can also check to see if do not disturb is on by seeing if there is a moon in your status bar
If you do not have the owner's manual, try removing it from the phone line and remove any batteries that it might have too. Completely removing any electrical source usually resets most electronics to its out of the box mode.
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device). Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
To apply Do Not Disturb on an extension: • Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. • Press the DND ON softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey. To remove Do Not Disturb on an extension: • Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB. • Press the DND OFF softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey.
Try a different cord and see if it works ok. If the circuit breaker trips without anything plugged into the extension cord then the chances are that there is a short in the socket of the cord or it is wired incorrectly.
Attendant To apply Do Not Disturb on an extension: • Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. • Press the DND ON softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey. To remove Do Not Disturb on an extension: • Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB. • Press the DND OFF softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey.
The phone that's mated to the DSS has a PROGRAM button. Press it, then press the button on the DSS console. Dial "1" plus the extenson number and STORE.
just used standard sockets with extenson, screw driver and phillips, remove head light and fender and fender guard cover. helper would really come in handy, so you dont scratch or drop fender.
It is hard to say which is 'best' - it depends what you want. Some have built in timers, some take 3 batteries for long shooting, some have portrait mode shutter releases...
Define 'best'.
