I have put up with a banding problem on my Lexmark c510 for over a year, along with a loud grinding noise when printing . The problem still occurs when print a separate page of each C Y M K colour. How...
Lexmark has nozzle check feature, which prints test
page so you can see if nozzles are working. It's under printer
properties/maintenance or similar.But depends which type of ink did you use for refilling. If you used so-called universal ink for all printers, then you're stuck. I tried such
ink on my Z33 and got same result. I ended with new Canon i550.If you did use such low-cost ink, i suggest you totally disassemblecartridge, clean it thoroughly, dry it and get new ink specially designed for Z65. When i got this result, i took out sponge, clean it, clean cart
itself until clean water was coming from nozzles, dried it out and refill. let me know the result.
